when I download a base map (Imagery) to my data frame does not georeference as my data frame
651
09-25-2018 02:27 PM
RitaPinto_de_Teal
is this a bug?
should I transform all my data to WGS84? O is there a way to fix this?
shan_sarkar
Rita,
Are you trying to georeference your data or is it already georeferenced?
Which projection are you using?
~Shan
~Shan
DanPatterson_Retired
Did you define a coordinate system for the dataframe or map before adding the basemap?
The first layer added determines the coordinate system, so if it is undefined things can go wrong
