Point value Change after projection - USGS DEM Raster VS Imagery Layer from Esri
3336
07-13-2022 10:26 AM
Jaslam
Hello Tech.
I'm working on a project that requires National level DEM data, and I'd like to thank ESRI for providing the imagery layer (https://www.arcgis.com/home/item.html?id=0383ba18906149e3bd2a0975a0afdb8e).
  1. For the most part, the extracted point values from the USGS raster and the ESRI imagery layer are very close. (Col 2 , Col 3 &Col 6)
  2. However, when I project those raster’s (WGS 1984 Web Mercator Auxiliary Sphere), the point value difference between projected raster’s from USGS and ESRI were significantly high. (Col 4, Col 5 & Col 7)
Shape *
Raster exported from USGS
      Raster exported from ESRI_layer
       USGS_Projected
          (WGS-1984)
    ESRI_layer_Projected
             (WGS-1984)
   Abs(Raster exported        from USGS-Raster    exported from   ESRI_layer)
Abs(USGS_Projected (WGS-1984)-ESRI_layer_Projected (WGS-1984))
Point
3071.917
3071.913
3032.042
3071.913
0.004
39.871
Point
3268.988
3268.984
3297.935
3268.984
0.004
28.951
Point
3496.321
3496.318
3488.198
3516.118
0.003
27.92
Point
2501.627
2501.627
2527.583
2501.627
Point
3253.484
3253.491
3246.843
3271.352
0.007
24.509
Point
2932.126
2932.129
2932.126
2955.189
0.003
23.063
Point
3088.094
3088.087
3088.094
3110.907
0.007
22.813
Point
2760.626
2760.628
2789.526
2766.848
0.002
22.678
Point
2647.81
2647.816
2625.496
2647.816
0.006
22.32
Point
2546.791
2546.793
2568.551
2546.793
0.002
21.758
Point
2973.761
2973.768
2955.436
2976.748
0.007
21.312
Point
2899.172
2899.171
2910.918
2889.789
0.001
21.129
Point
1535.169
1535.16
1535.169
1514.62
0.009
20.549
I tried various geographical transformations and resampling methods but received no improvement. What could be the cause of this, and how should I proceed?
Looking forward to hearing from You
2 Solutions
BojanŠavrič
Hi @Jaslam
I might have an answer for you, but I need a bit more information before I write a proper reply.
In which Projected/Geographic and Vertical Coordinate Systems is your Raster exported from USGS and Raster exported from ESRI_layer data?
I assume your target VCS for both datasets is WGS 1984, WKID::115700. Is this correct?
Bojan
BojanŠavrič
@Jaslam,
We look at your workflow and I might be able to provide you with an explanation.
These differences are caused by a resampling technique to source the projected rasters. In your case, this would be the Nearest Neighbor method. Since your USGS_1_n45w114_20130911 and ESRI_shape have different extents and raster grids, when they are projected to WGS84 Web Mercator, their projected grids aligned differently with the source raster grids and the Nearest Neighbor method picks different pixel to source its raster value. E.g. take your point with 3071.913 height from ESRI_shape_ProjectRaster layer and check all nearest 9 pixels round that point in USGS_1_n45w114_20130911. One of the pixels will have the height of 3032.042 as it is in USGS_Proj_NAD_1983_To_WGS_1984_5 layer. Differences vary based on the elevation changes in the point’s neighborhood. Some are higher, some lower, and some are exactly equal. Similar effect, but with a bit smaller differences happens with other resampling techniques for the same reason.
Please note that the Nearest Neighbor method is inappropriate for elevation surfaces. For more details, please check Project Raster online documentation page.
I hope this helps,
Bojan
BojanŠavrič
Hi @Jaslam
Bojan
Jaslam
Thanks @BojanŠavrič
Raster exported from ESRI layer -  XY =  NAD_1983 Z=None
Raster exported from USGS - XY =  NAD_1983 Z=None
Target Project coordinate system is WGS 1984.
For more info sharing data set:
https://vandalsuidaho-my.sharepoint.com/:f:/g/personal/mjaslam_uidaho_edu/EoPaEm7to6xNgLsBZbu0LIgBth...
Attached file info:
USGS_1_n45w114_20130911 - Raster Exported from USGS
USGS_Proj_NAD_1983_To_WGS_1984_5 - Projected Raster Exported from USGS
ESRI_shape - Raster Exported from ESRI (Clipping Geometry = ID2.shp)
ESRI_shape_ProjectRaster - Projected Raster Exported from ESRI (Clipping Geometry = ID2.shp)
ID2.shp - Lower Idaho state shape file
BojanŠavrič
@Jaslam,
I hope this helps,
Bojan
