Long Lat Help
2270
6
11-15-2023 11:58 AM
JummaKhan
I am using a 3rd party system that uses following values. Test Data is located in ONTARIO. It works with values
-8891974.7185355781.694
but not with -79.878 , 43.287
Can you please help how to convert this?
BojanŠavrič
@JummaKhan: These projected coordinate appear to be in Web Mercator (3857):
AyanPalit
@JummaKhan Looking at the coordinate values, you can try switching them as: 43.287, -79.878
Ayan Palit | Principal Consultant Esri
JummaKhan
Thanks for your response. unfortunately it is not working at lat,long.
Any idea what coordinates system is following values
BojanŠavrič
JummaKhan
How did you convert. please share conversion process for spread sheet
BojanŠavrič
I set my map to Web Mercator (3857) PCS and then I used Go To XY tool and I input your projected coordinates above, by changing units to meters:
By setting units to decimal degrees, I get the same point with geographic coordinates above:
SteveCole
Honored Contributor
It appears to be Web Mercator.
