Load tiles of map through UTM projection
6179
02-16-2016 10:52 PM
Maryameslamy
Hi Dear
I want to Use UTM projection to Load My Tiles. I did it formerly through Mercator projection. This is my code to create tiles in mecator projection.
private const double cornerCoordinate = 20037508.3427892
private const int WKID = 102100;
TileInfo = new TileInfo()
                Height = 256,
                Width = 256,
               Origin = new MapPoint(-cornerCoordinate, cornerCoordinate) { SpatialReference = new ESRI.ArcGIS.Client.Geometry.SpatialReference(WKID) },
                Lods = new Lod[20]
  double resolution = cornerCoordinate * 2 / 256;//180.0000 * 2 / 256;
the values in cornerCoordinate and WKID parameters is specialized for mercator projection. So, and it is my questions:
1: what are the values for cornercoordinate and WKID for UTM projection?
Unfortunately, I can not achieve suitable information in the net, please, Guide me.
thanks in advance
NeilAyres
What is WKID 102100?
I can find no reference to it in my docs. The closest 102101 and up is a bunch of coordsystems for Norway.
As for the corner coordinate, only you would know that?
Worldwide UTM zones (WGS84 based) are numbered 326 + zone number for the northern hemisphere and 327 + zone number for us in the south.
Maryameslamy
thanks Dear Neil
WKID = 102100 is an special reference for mercator projection. fortunately this WKIDworks correctly.
these links are related to it.
ESRI:102100: SR-ORG Projection -- Spatial Reference
http://www.faqoverflow.com/gis/253.html
I will appreciate you, if you clarify corner coordinate conception and its value (20037508.3427892) for me.
thanks in advance
NeilAyres
So 102100 is actually 3857 and has been like that since v10.0. That's why I can't find a reference to it.
So what is this :
(20037508.3427892)
Is that one big long number with 7 decimals or actually 2 numbers separated by ".".
A "Coordinate" implies at least 2 numbers, an X & a Y.
And which corner is it? LL, LR, UL, UR???
Maryameslamy
thanks a lot.
yes, you are right. these two values are equal.
please, look at this link
arcgis-toolkit-sl-wpf/WebTiledLayer.cs at master · Esri/arcgis-toolkit-sl-wpf · GitHub
that is a remarkable link to get beneficial information for loading tile layer.
in this code line
this.FullExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(-cornerCoordinate, -cornerCoordinate, cornerCoordinate, cornerCoordinate)
                SpatialReference = new SpatialReference(WKID)
and so it is equal to (Xmin,Ymin,Xmax,Ymax).
(Xmin,Ymin) Left Up
(Xmax,Ymax) Right Down
But as mentioned in this link, the values of  cornerCoordinate and WKID are set only mecator projection. I do not handle this code for UTM projection.
Best regards
Mary
