I am trying to digitize an old map. The projection is Lambert Conical Orthomorphic, It is a southern hemisphere map
I georeference the map (it is a scanned image, I've tried various projections) it appears to georeferecnce OK. But when I try to digitize various features as a layer, the digitised vector layers are (flipped over and spun thru 180 degrees). Advice desperately wanted, Anyone have any ideas?
thanks
How did you georeferenced it? and was latitude specified as negative? Longitude details?
Any specification would help
MKennedy-esristaff this may be for you
Thanks Dan for swift response, I set +ve latitude for Southern Hemisphere, my error
Just double-checking--you're good?
Melita, David had the latitudes flipped
Yes Melita, I'm sorted, simple error, my mistake, thanks for checking
