Labels Accumulate with Time
1511
09-25-2020 01:27 PM
by Anonymous User
Not applicable
Hi there!
I added a time layer to my map and it is working well. My data is presented every year for a 10 year period. Each year, however, a new label is added. I want the data points to be labeled, but after each year, I want the label to be replaced. At the end of the time period, the data points are surrounded by labels for each year. I want the year labels to increase as time progresses instead of adding more and more labels if that makes sense. Is there a way to make labels only show up for a set time?
Thank you!!
EdiePunt
Hi Grayson, I think the Time slider may give you what you need. Learn more here:
Visualize temporal data using the time slider—ArcGIS Pro | Documentation
by Anonymous User
Not applicable
I don't think the Time slider allows me to edit labels though. I have attached a video of the issue to better explain what I mean.
