How to remove unwanted point/label on the screen
810
10-13-2018 09:15 AM
IgnatiusRumambi
Hi There,
I am working on the statistics of annually earthquakes in Indonesia. Between about 1200 record, I just want to have 1 record with label (magnitude) appear on the screen, which is very important to me. I was not finished with the labeling, then this one green dot (see appendix) appear o the screen, and I can't remove it or change it. Even if I unchecked the layer at the TOC, the green dot will remain visible or if I delete this one record  on the table (see appendix as an example).
The only thing I want is that this green point away from the screen
Hopefully someone can help me with this, thanks in advance.
Regards.
Ignatius Rumambi
