How do I create a data frame buffer?
1125
04-02-2019 08:22 AM
BradSmith
Is there a quick and easy way to create a buffer around a data frame? I have some data layers that are geographically much larger than the data frame, and I would like to clip them so that they are only slightly larger than the data frame.
PanGIS
My day at work has just finished.
I don't guarantee that my answer isn't an idiocy
I would create a polygon as big as the data frame, then a buffer at x meters and use this to clip.....
BradSmith
Thank you for the reply. This is my fall back idea. I was just hoping that there is an easier way.
