How can I transform a polygon into a point?
5057
14
11-16-2017 02:24 PM
GB
Hi!
I have  a shapefile with polygons, but I want to transform these objects into points (example: I have the polygons with are the physical borders of a subset of school, I want to have point rather than the polygon of the building).
What can I use?
- feature to points doesn't suit me because it creates a new output, while I would like to keep the information I have in my original shapefile.
-I tried add geometry attributes, it runs successfully, but it doesn't not add the geometry attributes!!! Do you know why it happens?
Do you have other solutions?
Thank you!!
DanPatterson_Retired
You will need to produce a new output of some kind.  One of the easiest would be to calculate the X, Y (aka centroid) value for the center, then add it back in to the dataframe as an event layer saving to a point featureclass if you want
GB
Thank you. Do you know why the  add geometry attributesi is not woking? the tool runs successfully, but then in the table it doesn't add the geometry attributes!!!
show a screen grab of the table's first few rows.  There is a Shape field isn't there?.  There should be two new fields if you specified the centroid/center X and Y values
GB
I followed Dan Petterson's tip, and in the original layer (polygons) I added to new fields, and then calculated the geometry (x coordinate of the centroids, y coordinate of the centroids). Now, I would like to visualize these points on the map, how can I do that? Probably you Dan had already explained that ("then add it back in to the dataframe as an event layer saving to a point featureclass if you want"), but can you please write the passages? Thank you.
Go to the File Menu, select Add Data, Add XY Data.... then specify the value for the X field (ie Longitude) and the Y field (Latitude).
Once you have the event layer, right-click on it and you can select Data, Export Data, then specify in the dialog whether you want it to go to a folder as a shapefile (don't forget the *.shp file extension) or put it into a geodatabase as a featureclass.
GB
Hi, I tried it (also before writing the post), but it seems to me I can only select a table when using the ADD XY data. I'm using ARCGIS 10.5. I am working with  a feature class containing polygons.
you are effectively selecting the table of a featureclass... just makesure you are working with the table closed and the table of contents active.  It will use the table to produce the event layer if the table of contents is active.  Whatever you are doing, you are doing the same thing which is why it isn't working.  Add the table as and event layer, rightclick on that layer in the table of contents then export
GB
I am sorry, but when I open add XY Data, I can only choose a table. The only way that I found to visualize the centroids was to go to data management tools, layers and table views, make xy event layers.  But in this way I crreate a new output, and that is something I do not want to obtain.
The only way, through any method, that you can view the centroids of a polygon, is to create a new layer.
  1. I guess the word 'transform' can be interpreted differently.
  2. The 'keeping the attributes in the original shapefile' can definitely be accomplished using the process I have outlined
  3. features to points was definitely the wrong tool
  4. add geometry attributes is part of the 'event layer ' creation
So option 2.. using the 'event layer' creation work... once you have the event layer converted to a shapefile, you can simply toggle off the polygon layer and the visualization you desire will be complete, albeit with a new layer.
I guess this thread can be closed, although you don't like the answer
