Identify symbology (LocalMaps v3.1.2)
2240
02-13-2025 02:12 PM
Status: Implemented
Palmerston_NorthCity_Council
Users wanting to do prints or screenshots of an identified feature find that the transparent blue (polygon) obscure the property they want to highlight.
Can a configurable "IDENTIFY Symbology" section be added to the Admin functions.
The administrator should be able to set outline and fill colour and transparency for an identify action.
5 Comments
Aravindh_Rajendran
Hi @Palmerston_NorthCity_Council , Thanks for the post, we need some clarification on this. While selecting the features in the map, they are highlighted with the blue fill. When you try and print the map using the Print widget, you will get only the border highlighted without any fill. Can you check and see if this helps?
E.g.
That being said, having an option under admin to configure the fill colour and border colour sounds good, will add this to the backlog.
AndreKruger
Hi team,
If multiple polygons are highlighted by an Identify the transparency overlaps and in the end you cannot see 'through' the transparency anymore.
Often a print is not the 'desired' outcome.
People just want to see what is on the map without it being obscured..
Aravindh_Rajendran
Thanks @AndreKruger . This makes sense and gives a context, will add this to our backlog and notify once it is implemented.
Aravindh_Rajendran
Aravindh_Rajendran
Hello all, this has been implemented in 3.2x.
