Attribute Assistant: problem with 'Update_From/To_Edge_Field' function
1322
08-16-2017 07:31 AM
CalebAnderson1
First of all I just want to say that Attribute Assistant is great! I think this is ESRI at its best, it was relatively easy to set up, and it saves me a lot of headache and time working with our network utilities. However, everything is working correctly other than the "Update_From_Edge_Field" and "Update_To_Edge_Field" functions.
In my table of contents I have the wastewater mains (pipe) listed and displayed multiple ways in the TOC. If the mains are shown on the map in a layer that does not have a definition query, the "Update_From/To_Edge_Field" function works correctly (I add or edit a point and the new/updated point fields are passed to the main). However, if the main is displayed in a queried field, nothing happens. It doesn't seem like it should matter because the tool is referencing the root data, not the layer in the TOC.
Yesterday was my first time using AA so it could be me. Anybody else seen this before?
CalebAnderson1
Restarted and it's working now... Sooooo, nevermind
CalebAnderson1
