Attribute Assistant for creating GUID
1986
06-07-2018 06:42 AM
MeghanKulkarni
Hello Team,
I am having trouble using AA for creating GUID. Below is the snapshot of a DynamicValue table:
I have turned on debug mode and below is log file record:
############ 6/7/2018 9:15:55 AM ################
Setting sort order: Field - RUNORDER
Querying table for Last Value for layer: Addresses
Query Used: (TABLENAME = '*' OR TABLENAME = 'Addresses' OR TABLENAME like 'Addresses|*' OR TABLENAME like 'Addresses|%') AND VALUEMETHOD = 'Last_Value'
Number of results: 0
Querying table for rules for layer: Addresses
Query Used: (TABLENAME = '*' OR TABLENAME = 'Addresses' OR TABLENAME like 'Addresses|*' OR TABLENAME like 'Addresses|%') AND (ON_CHANGE = '1' or ON_CHANGE = 'Yes' or ON_CHANGE = 'YES' or ON_CHANGE = 'True' or ON_CHANGE = 'TRUE')
Number of results: 1
Looping through the rows
Row Info
Row Number 1
TableName: Addresses
FieldName: OBJECTID_1
ValueInfo: D
ValueMethod: GUID
On Create: 0
On Change: 1
Checking for Subtype Restriction
Field Name: OBJECTID_1 was found at index: 0
Finished: EXPRESSION
DONE
I am checking GenerateID table. Nothing shows up. Can someone help me with this?
My Best,
Meghan
Tags (1)
Florentino__Tino_Gomez
The dataset can be configured by right click, manage, add global IDs for automatic entry.
Otherwise, I use the following to populate an attribute field that is similar to the GlobalID field.
table name: (use * if you want this to apply to all feature classes)
Field Name: (enter the name of the field that you want the GUID in)
Value Method: GUID
Value Info: B
for other values:  N, D, P
visit:
All methods - Attribute Assistant | ArcGIS Solutions
(documentation, All Methods) scroll down to:  GUID
JoeBorgione
Is FIELDNAME supposed to be <Null>?
That should just about do it....
no.  type the name of the attribute field that will have the GUID data.
In our case, the attribute field name is called, "sdsID" or "GlobalID"
attached is a screen shot, still working improving on how NOT to populate the attributes that are NOT NULL.  work in progress.
I downloaded some of the other industry workflows examples to get ideas and somewhere i got a bunch of examples that others had uploaded.  here is the link to them, hope the links work:  https://community.esri.com/message/590427
see GUID at All methods - Attribute Assistant | ArcGIS Solutions
JoeBorgione
That was a rhetorical question....  I'm not the one having problems with it; personally, I don't use GUIDS for anything but replication....
