Thoughts on Using 'Integrate' GP Tool to Enforce Coincidence in Parcel Data
2944
06-29-2016 04:22 AM
LarryGaudieri
Reading some ESRI documentation (Load Parcel Polygons, v10.3) located here:
Load parcel polygons—Help | ArcGIS for Desktop
I've talked to some people that didn't agree with using the tool for concerns about hiding possible data creation errors  record problems from plat, legal or deed.
Could anyone share their opinions?
AmyAndis
In the ‘Load parcel polygons’ help documentation using the Integrate tool is just one of many options that is available to enforce coincidence between datasets.  Using Integrate is not a requirement. Please note that the Integrate tool is an option when you are starting with only Parcel Polygons.
In your post you mention “record problems from plat, legal or deed” if you are starting with only Lines then please look at the help documentation for ‘Load parcel lines with COGO dimensions’
http://desktop.arcgis.com/en/arcmap/latest/manage-data/editing-parcels/loadcogo.htm
If you are starting with only Parcel Polygons I suggest that you really know the types of errors in your data to determine if this is the right tool to use to achieve coincidence.  Please read through the Integrate documentation to get a better feel of how this tool works and how the XY tolerance value can affect the input polygon datasets.  Please note when working with Integrate on any features you need to be aware that this tool does not give you a new output so it is recommended that this tool be used on copies of your data.  I also suggest that you run this tool on small subsets of data so you can examine the results and test different XY tolerances.
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/integrate.htm
AmyAndis
LarryGaudieri
Thank you Amy. I've decided to forego using it in my model. I know the Esri documentation suggests it as part of the work-flow but there's no guarantee the tool will make coincidence according to plat or deed. So, I'm letting the matter go to topological review and compare any violations to the record to make a decision on how to repair. Thank you for your answer!
