Post-processing question about records
775
07-30-2019 09:28 AM
DavidMinton
During the upgrade of an ArcMap parcel fabric one of the recommended steps in the post-processing stage is to "Delete large records like <Map>  (on staging file geodatabase)"  What is the rationale for this and what would generally be considered a "large" record?  Quarter Section size, Section size, Township size, 9200 square mile size?
Parcel Fabric - Migrating and Administrating Parcels with ArcGIS Pro SLide
JasonCamerano
The <map> record is usually overlapping much of the data so making a change somewhere in the data that has the <map> record within the extent might cause that feature to be updated which could cause performance slow down.  This issue will be addressed with ArcGIS Pro 2.5.
