ArcGIS Parcel Fabric: Reset Adjustments/Transformations?
6794
10
03-31-2015 08:30 AM
BrandonPlewe1
So I'm learning how to use parcel fabrics, and getting frustrated so far. I attempted to do an adjustment on one of my subdivision plans (600 parcels). I thought it worked, so I saved it. Then on closer inspection, I realized that ArcGIS had totally mangled my parcels. However, since I saved it, UNDO is no longer an option. Is there a way to reset the geometry for a parcel/plan/fabric back to the internal (COGO) geometry so I can start again?
It appears that the only help I can find from Esri on this is to delete the parcels and enter them again, but this seems like an idiotic "solution" (especially for 600 parcels). I have tried unjoining and rejoining them, but this keeps the warped geometries. I may be remembering things wrong, but it seems like the old survey analyst handled things like this much better.
Tags (1)
TimHodson
Brandon, it's great to see your leveraging of the fabric adjustment in this way. "Un-adjust by adjust" ... I like it! This really helps to show-case the power of the adjustment technique, the use of temporary control, and also the the fabric model and its design. Thanks for the update.
