Kotlin Real Time Sample App
1645
10-02-2023 06:56 PM
LeighWoolley
Is there an equivalent Kotlin SDK sample app to the Java SDK:
add_custom_dynamic_entity_data_source
Shubham_Sharma
Hey @LeighWoolley,
The Add custom dynamic entity data source Kotlin sample is planned for the next SDK release, although the implementation should be fairly similar to Java. The API is supported in the Kotlin ArcGIS Maps SDK in version 200.2.0: API ref
Configure the custom data source:
  • Create a custom data source implementation of a CustomDynamicEntityDataSource.
val dataSource = CustomDynamicEntityDataSource(
    FlowBuilderProvider(lifecycleScope, observationsFile)
  • Override onLoad() to specify the DynamicEntityDataSourceInfo for a given unique entity ID field and a list of Field objects matching the fields in the data source.
  • Override onConnect() to begin processing observations from the custom data source.
  • Loop through the observations and deserialize each observation into a Geometry object and a Map<String, Object> containing the attributes.
  • Use CustomDynamicEntityDataSource.FeedEvent.NewObservation to add each observation to the custom data source.
private class FlowBuilderProvider(
    scope: CoroutineScope,
    val observationsFile: File
) : CustomDynamicEntityDataSource.EntityFeedProvider {
    private val _feed: Flow<CustomDynamicEntityDataSource.FeedEvent> = flow {
        // set up the bufferedReader on the observationsFile
        // for each line of the file retrieve the geometry, field name and value for the observation
        emit(
            CustomDynamicEntityDataSource.FeedEvent.NewObservation(
                geometry,
                mapOf(trackIdField to trackIdValue)
    override val feed: SharedFlow<CustomDynamicEntityDataSource.FeedEvent> =
        _feed.flowOn(Dispatchers.IO).shareIn(scope, SharingStarted.WhileSubscribed())
    override suspend fun onLoad(): DynamicEntityDataSourceInfo {
        return DynamicEntityDataSourceInfo(
            entityIdFieldName = trackIdField,
            fields = listOf(Field(FieldType.Int64, trackIdField, trackIdField))
        ).apply { spatialReference = SpatialReference.wgs84() }
    override suspend fun onConnect() {}
    override suspend fun onDisconnect() {}
Configure the map view:
  • Create a DynamicEntityLayer using the custom data source implementation.
  • Update values in the layer's TrackDisplayProperties to customize the layer's appearance.
val layer = DynamicEntityLayer(dataSource).apply {
    trackDisplayProperties.showPreviousObservations = false
    trackDisplayProperties.showTrackLine = true
    trackDisplayProperties.maximumObservations = 40
operationalLayers.add(layer)
Shubham_Sharma
Hey @LeighWoolley,
        emit(
                geometry,
LeighWoolley
Great, thank you,
