Kotlin Maps SDK not rendering fill layer defined with match statement in JSON stylesheet
1168
09-23-2024 03:05 PM
IgnisDev
Hello ESRI folks!
Question:  Does the Kotlin & iOS SDK (also web SDK) support match statements in JSON stylesheets to represent multiple fill colors for a vector tile layer?
Context:
Our team is migrating from using MapBox to render vector tiles produced by pg_tileserve for our Android & iOS to the ESRI SDKs. We're having trouble with the SDKs rendering layers that have fill-color stylesheet specifications.
Current Solution:
Our current solution is leveraging the ArcGISVectorTiledLayer to read the stylesheets for vector tile layers.
fun LayerDescriptor.toArcGISLayer(): ArcGISLayer {
return when (layerCase) {
LayerDescriptor.LayerCase.VECTOR_LAYER -> {
ArcGISVectorTiledLayer(vectorLayer.stylesheetJsonUrl).apply {
name = layerName
Supporting Details:
Here's the stylesheet JSON that corresponds to the screenshots below.
  "layers": [
      "id": "Severe Fire Danger Index",
      "layout": {
        "visibility": "visible"
      "paint": {
        "fill-color": [
          "match",
            "get",
            "sfdi_value"
          "LOW",
          "rgba(42 ,131, 187, 1)",
          "MODERATE",
          "rgba(171, 221 ,164, 1)",
          "HIGH",
          "rgba(253, 254 ,190,1)",
          "VERY HIGH",
          "rgba(253 ,174, 97,1)",
          "SEVERE",
          "rgba(215, 25, 27,1)",
          "rgba(0, 0, 255, 0.5)"
        "fill-opacity": 0.7
      "source": "sfdi",
      "source-layer": "public.sfdi_ignis_zone",
      "type": "fill"
  "sources": {
    "sfdi": {
      "maxZoom": 14,
      "minZoom": 0,
      "tiles": [
          "https://ourtileserveraddress/public.sfdi_ignis_zone/{z}/{x}/{y}.pbf"
      "type": "vector",
      "volatile": true
  "version": "8"
Attaching a screenshots of what the tiles should look like...
This is how it currently renders in the Android emulator...
GuntherHeppner
@IgnisDev - the Kotlin & Swift SDKs don't support match statements in JSON stylesheets and there is no plan to support them in the future.
In terms of solutions/workarounds, you might want to look at the tile spec that Esri supports, using:
- Esri's vector basemaps
- the Esri Vector Tile Style Editor
