How to statistic vector area from a local featureLayer in Kotlin SDK
507
09-27-2025 05:49 PM
LiqiangZhu
I am developing an Android application using the ArcGIS Maps SDK for Kotlin (version 200.6).I'm currently using StatisticsQueryParameters to perform statistics on other attribute fields in the FeatureTable, and it works well. Now I need to statistic vector area.
        val statisticDefinition = StatisticDefinition(
            areaFieldName, metricFieldStatisticType, areaFieldAlias
        statisticDefinitions.add(statisticDefinition)
        val queryParameters = StatisticsQueryParameters(statisticDefinitions).apply {
            groupByFieldNames.add(firstLevelGroupByFieldName)
            secondLevelGroupByFieldName?.let {
                groupByFieldNames.add(it)
            boundary?.let {
                geometry = it
        featureTable.queryStatistics(queryParameters).onSuccess { statisticsQueryResult ->
            statisticsQueryResult.forEach { statisticRecord ->
                val groupMap = statisticRecord.group
                val statisticsMap = statisticRecord.statistics
                val tableQueryByLevelRow = TableQueryRow.TableQueryByLevelRow(
                    firstLevelValue = groupMap[firstLevelGroupByFieldName].toString(),
                    secondLevelValue = groupMap[secondLevelGroupByFieldName]?.toString(),
                    metricFieldValue = formatStatisticValue(statisticsMap[areaFieldAlias])?:"",
                result.add(tableQueryByLevelRow)
        }.onFailure { e ->
            throw e
 I know how to statistic the total area by iterating through each feature, getting its geometry, and summing areas.
Is there a better or more efficient method to statistic vector area?
RamaChintapalli
If you have enabled Shape_Area field on your feature layer, then you can use it as the attribute to perform the statistics query on it to compute the SUM/Average etc.
Rama
