Draw a polygon using the saved Geometry data ( Not using SketchEditor)
711
01-23-2024 04:37 PM
DeepamPalaniswami
Hi Team,
 I have successfully integrated the sketchEditor and able to draw polygon, undo, redo etc.
I have saved the geometry info in a Table and I wanted to redraw the saved geometry.
I have below code snippet trying to draw the saved geometry polygon.
fun drawn(geometry: Geometry) {
// create a graphic from the sketch editor geometry
val graphic = Graphic(geometry)
// add the graphic to the graphics overlay
graphicsOverlay.graphics.add(graphic)
 But I am not seeing the saved polygon. Need your help and insight in this regard.
DeepamPalaniswami
I was missing the drawlines thats why I can't see the lines. Once drawn problem solved.
All good . thanks.
RamaChintapalli
Can you check if your graphicsOverlay is included in the Mapview's graphicOverlays collection?
Thanks
Rama
DeepamPalaniswami
All good . thanks.
