Compose MapView ignores isAttributionBarVisible=false
2382
5
04-26-2024 06:54 AM
dev4567
Context
Using
com.esri:arcgis-maps-kotlin-toolkit-geoview-compose:200.4.0
Issue
MapView(
  isAttributionBarVisible = false
Attribution bar is still shown.
Hacky Solution
@Composable
private fun rememberAttributionBarVisibility(): Boolean {
    // must be true by default - value must change to be applied
    var isAttributionBarVisible by remember { mutableStateOf(true) }
    SideEffect {
        // fix attribution bar is not hidden by default
    return isAttributionBarVisible
Tags (1)
Shubham_Sharma
After some more investigation, it seems like this is happening with older compose versions. Could you try updating to a more recent Compose BOM version (2024.01.00 or above)?
Shubham_Sharma
@dev4567 The MapView should be able to work with your original approach by passing in an isAttributionBarVisible to the MapView
Check out the Display Composable MapView sample app, I'm able to toggle the attribution bar.
Could you provide more context on the Composable layout you are using and how exactly is the MapView being used?
Shubham_Sharma
dev4567
I confirm it works, thanks! The error occurred on 2024.03.00, but with 2024.05.00 it seems to be fine.
dev4567
@Shubham_Sharma we still see attribution bar is blinking on startup with the latest compose bom=2024.09.02 and sdk=200.5. We believe the problem is it's somehow linked with a Basemap loading – as our app starts with an empty `Basemap()` and then we add layers dynamically. Also, from what I see in the decompiled code, `isAttributionBarVisible` by default is `true` – probably we could advise change this to `false` by default?
Shubham_Sharma
Thank you for reaching out to us regarding attribution bar. We have identified the bug issue, and will provide the fix in the next ArcGIS Maps SDK Kotlin release.
