Authenticate with OAuthApplicationCredential in kotlin android app
1273
10-18-2023 03:37 AM
FatmaAlzhraa
i have "portalUrl","clientId","clientSecret" and i want  Authenticate with OAuthApplicationCredential in kotlin android app
and store this credential to view map in portal and access services in server
Shubham_Sharma
@FatmaAlzhraa You can create a class that implements the ArcGISAuthenticationChallengeHandler interface to handle the authentication.
class ArcGISCredentialAuthenticationChallengeHandler(
    val createCredential: suspend () -> Result<ArcGISCredential>
) : ArcGISAuthenticationChallengeHandler {
    override suspend fun handleArcGISAuthenticationChallenge(challenge: ArcGISAuthenticationChallenge): ArcGISAuthenticationChallengeResponse {
        val result = createCredential()
        return result.let {
            if (it.isSuccess) {
                ArcGISAuthenticationChallengeResponse.ContinueWithCredential(it.getOrThrow())
            } else {
                ArcGISAuthenticationChallengeResponse.ContinueAndFailWithError(it.exceptionOrNull()!!)
Now you can use this class to set the AuthenticationManager using your client ID and secret:
val arcGISChallengeHandler = ArcGISCredentialAuthenticationChallengeHandler {
    OAuthApplicationCredential.create(
        portalUrl = "myPortalURL",
        clientId = "myClientId",
        clientSecret = "myClientSecret",
        tokenExpirationInterval = 0
ArcGISEnvironment.authenticationManager.arcGISAuthenticationChallengeHandler = arcGISChallengeHandler
val portal = Portal("myPortalURL", Portal.Connection.Authenticated)
lifecycleScope.launch {
    portal.load().onSuccess {
        println("Success!")
    }.onFailure {
        println("Failed to load portal ${it.printStackTrace()}")
