ArcGIS (API for Python) on a Raspberry Pi: Happy Pi Day!
7167
03-14-2019 11:08 AM
TomBaker
Technically, it's the wrong Pi but hey, it's close enough for Pi Day.....
For those schools and after school clubs that use Raspberry Pi micro-computers, I've posted a working set of
instructions to get the ArcGIS API for Python running on a Pi 3.  See the draft.
Happy Pi Day!
Tags (3)
CityGIS
I have been trying to get this to run, but when I open Jupyter and try to make a map, it tells me that arcgis module is not installed.  I have seen that it installed and I am running Python 3.6.1 and would like to get this working as a step towards building a PI that can add points to a map with the push of a button, and remove those points, just as easily.  Any ideas why it can't find the arcgis module?
TomBaker
With package manager are you using?  I used Berryconda for that installation.
BrianBaldwin
@TomBaker - Your link above '404's - is this 'dead' or does it still exist?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
TomBaker
Thanks Brian.  Link above updated.  I have not yet had time to verify the process still works four years later.  😁
