Which version of Eclipse should I install?
3668
09-16-2014 02:45 PM
KeithUnger
I've gone to the Eclipse download site and see two versions. Do I download the standard or the Java EE version??
EliseAcheson1
If you're not sure you can probably stick to the Standard version. The supported versions of eclipse are listed on the system requirements page under 'Supported and Recommended IDE(s)' table.
~elise
EliseAcheson1
~elise
KeithUnger
Thank you for your suggestion! The standard version is working fine.
