valid local server installation could not be found
1146
08-10-2020 11:26 AM
GiridharPragada
I installed the local server 100.8. When I run the local server in sample viewer it pops up local server installation could not be found. Are there some settings that need to be updated?
Giridhar
MarkBaird
I suspect I know the problem here.  Although the latest version of Local Server and Runtime is 100.8, we've not released 100.8 of the sample viewer.  I suspect you are using 100.7 for the sample viewer which won't work with the latest Local Server.
To get this working, you have a couple of options:
 - Run the sample in your IDE (inteliJ for example) using the latest 100.8 version of Runtime (this is what I strongly recommend)
 - If you want to use the 100.7 sample viewer, then you will need to install Local Server 100.6.
Does this help?
