Topology parents  java.lang.NoSuchFieldError: m_pFC issue
2228
05-26-2012 08:47 AM
AndrewEvans
Hi all,
I was wonder if anyone else had had a problem with getting topology parent objects and knew what this issue was. I'm trying to access topology edge parents within an add-in, and currently getting the following error:
at com.esri.arcgis.interop.NativeObjRef.nativeVtblInvokeNative(Native method)
at com.esri.arcgis.interop.NativeObjRef.nativeVtblInvoke(Unknown Source)
at com.esri.arcgis.interop.Dispatch.vtblInvoke(Unknown Source)
at com.esri.arcgis.geodatabase.IEnumTopologyParentProxy.next(Unknown Source)
at... [my line (see below)]
I noticed someone else had the same issue (without an answer) on the old forums in 2005.
Details:
I have a topology layer set up with two feature classes associated with it, and these are turned on. All of these are in a Feature Dataset in a Personal Geodatabase.
All three are in as Layers, each appearing in the ToC, un-nested (I only mention this, because I have seen the same thing nested somehow into the topology layer on other machines but can't replicated it on mine). Both feature class layers contain relatively simple polyline features.
I am using the following code in the add-in. I note that its an add-in, as I've had no luck getting some of the more standard topology code people use working in that environment. I've left out the try-catches and simplified it a bit for clarity.
Any ideas? Everything I've seen in the C#/VB examples suggests it should work. Am I missing something obvious?
Many thanks, Andy.
// Initialise various bits - meat of code in section beyond
mxDoc = (IMxDocument)app.getDocument();
map = mxDoc.getFocusMap();
TopologyLayer topologyLayer = null;
for (int i=0; i < map.getLayerCount(); i++) {
    ILayer iLayer =  map.getLayer(i); // Works: can get name.
    if (iLayer instanceof TopologyLayer) {
        topologyLayer = (TopologyLayer) map.getLayer(i); // Works: can get name.
    } else {
        // Get other layers as IGeoFeatureLayers - works fine.
// Code to get the parents
ITopology it = topologyLayer.getTopology();
ITopologyGraph iTopologyGraph = (ITopologyGraph) it.getCache();
IEnvelope ie = mxDoc.getActiveView().getExtent(); // Run with whole map visible
iTopologyGraph.build(ie, true); // Can check extents fine
IEnvelope dirtyE = it.validateTopology(ie); // Returns null, which I think it should.
IEnumTopologyEdge iEnumTopologyEdges = iTopologyGraph.getEdges(); // Have also tried with nodes
iEnumTopologyEdges.reset();
ITopologyEdge ite = iEnumTopologyEdges.next(); // Can print the length of ite's associated geometry
IEnumTopologyParent iEnumTopologyParent = (IEnumTopologyParent)ite.getParents();
    // Have also tried getting the parents by IGeoFeature layer object selection, and from the topologyGraphy.
    // I can select objects in the topology layer by objects in the IGeoFeature layers, and successfully
    // print their lengths, so I know they are tied together somehow.
tagesriTopologyParent pp = iEnumTopologyParent.next(); // Error generated here. Also generates error if I try to
      // just directly read the attributes without the variable label, just using .next().
AndrewEvans
Ok, haven't solved this, but worked around it by using the topology elements to select the intersecting elements in the layers using a SpatialFilter applied to each layer in turn, e.g.
spatialFilter.setGeometryByRef((Point) iTopologyNode.getGeometry());
spatialFilter.setSpatialRel(esriSpatialRelEnum.esriSpatialRelIntersects);
spatialFilter.setGeometryField(layerFeatureClassProxy.getShapeFieldName());
featureCursor = new FeatureCursor(iGeoFeaturelayer.search(spatialFilter, false));
Would still be interested to know about the above though, as I'm bound to need it sooner or later. On the face of it, it looks unpleasant (http://docs.oracle.com/javase/7/docs/api/java/lang/NoSuchFieldError.html), but I may be missing something obvious.
