The 10.2 release is now available!
3814
7
11-05-2013 10:21 AM
MarkBaird
I�??m pleased to announce that the 10.2 release of the ArcGIS Runtime SDK for Java is now available and for the first time it is available for download at our newly designed developers site.
There is lots of new functionality, some of which has been created as a result of popular requests from this forum.  For a full list of functionality, please look at our what�??s new section.
Released as beta functionality in this release, we have an exciting suite of offline functionality which allows users to create applications that can take enterprise data into environments where there is no network connectivity to perform routing, geocoding, data viewing, and editing.  Offline editing can then be synchronised back to enterprise datasets once a network connection is available again.  For the first time, this functionality is available for all ArcGIS Runtime APIs including Android, iOS, Qt, OS X, .Net and of course Java SE!
JeremieJoalland1
Great news !! 🙂
When accessing my ESRI Global account on https://customers.esri.com/, is it normal that I don't see ArcGIS Runtime SDK 10.2 ? (only 1.0 and 10.1.1 are available).
From the ArcGIS for Developers new site, in order to download the SDK, it requires another account ? could you clarify this regarding customer with an EDN ?
Thanks.
MarkBaird
In order to download the 10.2 API you will need to register for a developers account.
I'll let Eric clarify the EDN position.
Mark
EricBader
Honored Contributor
Mark
Mark is correct.
To add, regarding EDN subscribers, they will also be re-directed to the developers.arcgis.com pages and will need to acquire a free developer subscription to access all of the SDKs. I hope this helps!
JeremieJoalland1
Could you confirm to me that I can install SDK 10.2 on my machine (WinXP) and keep SDK 10.1.1 installed ?
or do I need to uninstall 10.1.1 first ?
MarkBaird
The 2 versions will work side by side... but you can't have the 2 Eclipse plugins in one install of Eclipse.
Mark
CarlosColón-Maldonado
The new site doesn't seem to allow downloads of this version since the newest release. Is there a way to get this version downloaded? This one never made it to the customer portal software list.
EliseAcheson1
You should be able to download the 10.2 version on the downloads page (when logged in) at https://developers.arcgis.com/en/downloads/.
Next to the 'ArcGIS Runtime SDK for Java' title there's a drop down where you can switch from the 10.2.3 downloads to the 10.2 ones, pictured below.
[ATTACH=CONFIG]34862[/ATTACH]
~elise
