Setting Impedance Cutoffs in Java
1150
09-19-2019 03:31 PM
jamesgirard
When solving for a service area in java, how does one set the impedance cutoffs or default breaks as per this document:
Generate service areas—ArcGIS Runtime SDK for Java | ArcGIS for Developers
under the Other Service Area Parameters properties section.
ServiceAreaParameters doesn't have a setImpedanceCutoffs() or setDefaultBreaks() method, as would seem to be implied by the document.  It does have a getDefaultImpedanceCutoffs() method.
Neither does ServiceAreaFacility.
Thanks!
-J
JonL
by Esri Alum
Esri Alum
Hi James,
you can set the impedance parameters to your desired value(s) by first clearing the default parameters:
serviceAreaParameters.getDefaultImpedanceCuttoffs().clear();
And then adding your own values into the default impedance cuttoffs, e.g. for 1 and 3 min:
serviceAreaParameters.getDefaultImpedanceCuttoffs().addAll(Arrays.asList(1.0, 3.0));
Hope this answers your question, please let us know if you have any further problems.
Jonathan
jamesgirard
Worked fantastic - thank you!
