RunTimeException when trying to display military messages
1894
10-23-2016 02:40 PM
DarkRider
I am using ArcGIS 10.2.4.6 and Eclipse Neon.1 on Windows 7
I've followed the following tutorial:
Display military messages—ArcGIS Runtime SDK for Java | ArcGIS for Developers
For that I've created an ArcGIS Map application. I've attached the code file.
When I run the code, I get the following error message:
java.lang.RuntimeException: Internal error exception - Group layer is not bound to map, or map not initialized
    at com.esri.core.internal.symbol.advanced.MessageProcessorInternal.nativeProcessMessage(Native Method)
    at com.esri.core.internal.symbol.advanced.MessageProcessorInternal.a(Unknown Source)
    at com.esri.core.symbol.advanced.MessageProcessor.processMessage(Unknown Source)
    at MainClass$2.run(MainClass.java:94)
    at java.awt.event.InvocationEvent.dispatch(Unknown Source)
    at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
    at java.awt.EventQueue.access$500(Unknown Source)
    at java.awt.EventQueue$3.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
    at java.awt.EventQueue.dispatchEvent(Unknown Source)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
    at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
    at java.awt.EventDispatchThread.run(Unknown Source)
Although the group layer is bound to the map and the map is initialized. Can anybody help me with this?
nita14
//EDITED - MAP is not yet ready
Map is not yet initialized. Try to add "addMapEventListener" to the map, and then process the message in the mapReady method.
map.addMapEventListener(new MapEventListener(){
@Override
public void mapDispose(MapEvent arg0) {
// TODO Auto-generated method stub
@Override
public void mapExtentChanged(MapEvent arg0) {
@Override
public void mapReady(MapEvent arg0) {
Hope this helps,
Adam
