Problems with route finding
3419
12-03-2014 06:02 PM
LeeLee
I am using the ArcGIS Runtime SDK 10.2.4 for Java. My aim is to find a route between two stops from a network dataset embedded in a runtime geodatabse. But I found that sometimes the result was right, sometimes the result was wrong, and sometimes the result was not consistent with the result got by the ArcMap network analyst extension. I don’t know what the problems were. The source network dataset and the runtime geodatabse can be downloaded from http://pan.baidu.com/s/1kTrAXsb. My test was from the start stop (2.229991, 5.538746) to the target stop (7.512169, 5.101842), and I got an obviously wrong route. Can someone test the data and give my some suggestions? Thank you very much!
