Problems adding jMap to jPanel
3681
09-21-2015 06:20 AM
DavidJones17
Welcome everyone.
I have some problems adding jMap to jPanel. Im pretty new at ArcGis Runtime and Java Programming language. I want to add simple map to the jPanel shown below(green colour). I used NetBeans to make gui and some code is generated automatically.
This is my code:
<code>
import com.esri.map.JMap;
import com.esri.map.MapOptions;
import gui.SimpleMap;
import java.awt.BorderLayout;
import java.util.logging.Level;
import java.util.logging.Logger;
import javax.swing.*;
* @author Wojtek
public class Main extends JFrame {
      * Creates new form Main
     public Main() throws Exception {
          initComponents();
          addMap();
     @SuppressWarnings("unchecked")
     // <editor-fold defaultstate="collapsed" desc="Generated Code">
     private void initComponents() {
          jSplitPane1 = new javax.swing.JSplitPane();
          jPanel5 = new javax.swing.JPanel();
          jLabel6 = new javax.swing.JLabel();
          jTextField4 = new javax.swing.JTextField();
          jLabel7 = new javax.swing.JLabel();
          jTextField5 = new javax.swing.JTextField();
          jLabel8 = new javax.swing.JLabel();
          jTextField6 = new javax.swing.JTextField();
          jLabel9 = new javax.swing.JLabel();
          jLabel10 = new javax.swing.JLabel();
          jPanel4 = new javax.swing.JPanel();
          jTabbedPane1 = new javax.swing.JTabbedPane();
          jPanel1 = new javax.swing.JPanel();
          jPanel3 = new javax.swing.JPanel();
          jLabel1 = new javax.swing.JLabel();
          jTextField1 = new javax.swing.JTextField();
          jLabel2 = new javax.swing.JLabel();
          jTextField2 = new javax.swing.JTextField();
          jLabel3 = new javax.swing.JLabel();
          jTextField3 = new javax.swing.JTextField();
          jLabel4 = new javax.swing.JLabel();
          jLabel5 = new javax.swing.JLabel();
          jLabel11 = new javax.swing.JLabel();
          jTextField7 = new javax.swing.JTextField();
          jLabel12 = new javax.swing.JLabel();
          jTextField8 = new javax.swing.JTextField();
          jLabel13 = new javax.swing.JLabel();
          jTextField9 = new javax.swing.JTextField();
          jLabel14 = new javax.swing.JLabel();
          jButton1 = new javax.swing.JButton();
          jPanel2 = new javax.swing.JPanel();
          jLabel6.setText("Współrzędne WGS-84");
          jTextField4.addActionListener(new java.awt.event.ActionListener() {
               public void actionPerformed(java.awt.event.ActionEvent evt) {
                    jTextField4ActionPerformed(evt);
          jLabel7.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
          jLabel7.setText(" φ");
          jTextField5.addActionListener(new java.awt.event.ActionListener() {
                    jTextField5ActionPerformed(evt);
          jLabel8.setText("°");
          jTextField6.addActionListener(new java.awt.event.ActionListener() {
                    jTextField6ActionPerformed(evt);
          jLabel9.setText("'");
          jLabel10.setText("\"");
          javax.swing.GroupLayout jPanel5Layout = new javax.swing.GroupLayout(jPanel5);
          jPanel5.setLayout(jPanel5Layout);
          jPanel5Layout.setHorizontalGroup(
               jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addGroup(jPanel5Layout.createSequentialGroup()
                    .addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
                              .addContainerGap()
                              .addComponent(jLabel7)
                              .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
                              .addComponent(jTextField4, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel8, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField5, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel9)
                              .addComponent(jTextField6, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel10))
                              .addGap(75, 75, 75)
                              .addComponent(jLabel6)))
                    .addContainerGap(85, Short.MAX_VALUE))
          jPanel5Layout.setVerticalGroup(
                    .addGap(23, 23, 23)
                    .addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
                              .addComponent(jLabel8, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                              .addGap(3, 3, 3))
                         .addGroup(jPanel5Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
                              .addComponent(jTextField4, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel7, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField5, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField6, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel10)))
                    .addContainerGap(436, Short.MAX_VALUE))
          javax.swing.GroupLayout jPanel4Layout = new javax.swing.GroupLayout(jPanel4);
          jPanel4.setLayout(jPanel4Layout);
          jPanel4Layout.setHorizontalGroup(
               jPanel4Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addGap(0, 796, Short.MAX_VALUE)
          jPanel4Layout.setVerticalGroup(
               .addGap(0, 0, Short.MAX_VALUE)
          setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
          jPanel1.addComponentListener(new java.awt.event.ComponentAdapter() {
               public void componentShown(java.awt.event.ComponentEvent evt) {
                    jPanel1ComponentShown(evt);
          jLabel1.setText("WGS-84 Coords");
          jTextField1.addActionListener(new java.awt.event.ActionListener() {
                    jTextField1ActionPerformed(evt);
          jLabel2.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
          jLabel2.setText(" φ");
          jTextField2.addActionListener(new java.awt.event.ActionListener() {
                    jTextField2ActionPerformed(evt);
          jLabel3.setText("°");
          jTextField3.addActionListener(new java.awt.event.ActionListener() {
                    jTextField3ActionPerformed(evt);
          jLabel4.setText("'");
          jLabel5.setText("\"");
          jLabel11.setFont(new java.awt.Font("Tahoma", 0, 12)); // NOI18N
          jLabel11.setText("λ");
          jTextField7.addActionListener(new java.awt.event.ActionListener() {
                    jTextField7ActionPerformed(evt);
          jLabel12.setText("°");
          jTextField8.addActionListener(new java.awt.event.ActionListener() {
                    jTextField8ActionPerformed(evt);
          jLabel13.setText("'");
          jTextField9.addActionListener(new java.awt.event.ActionListener() {
                    jTextField9ActionPerformed(evt);
          jLabel14.setText("\"");
          jButton1.setText("jButton1");
          jButton1.addActionListener(new java.awt.event.ActionListener() {
                    jButton1ActionPerformed(evt);
          javax.swing.GroupLayout jPanel3Layout = new javax.swing.GroupLayout(jPanel3);
          jPanel3.setLayout(jPanel3Layout);
          jPanel3Layout.setHorizontalGroup(
               jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addGroup(jPanel3Layout.createSequentialGroup()
                    .addContainerGap()
                    .addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
                         .addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.TRAILING)
                                   .addComponent(jLabel11)
                                   .addComponent(jTextField7, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                                   .addComponent(jLabel12, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
                                   .addComponent(jTextField8, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                                   .addComponent(jLabel13)
                                   .addComponent(jTextField9, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
                                   .addComponent(jLabel14))
                                   .addComponent(jLabel2)
                                        .addComponent(jLabel1)
                                             .addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                                             .addComponent(jLabel3, javax.swing.GroupLayout.PREFERRED_SIZE, 5, javax.swing.GroupLayout.PREFERRED_SIZE)
                                             .addComponent(jTextField2, javax.swing.GroupLayout.PREFERRED_SIZE, 23, javax.swing.GroupLayout.PREFERRED_SIZE)
                                             .addComponent(jLabel4)
                                             .addComponent(jTextField3, javax.swing.GroupLayout.PREFERRED_SIZE, 35, javax.swing.GroupLayout.PREFERRED_SIZE)
                                             .addComponent(jLabel5)))))
                              .addGap(86, 86, 86)
                              .addComponent(jButton1)))
                    .addContainerGap(14, Short.MAX_VALUE))
          jPanel3Layout.setVerticalGroup(
                    .addGap(23, 23, 23)
                    .addComponent(jLabel1, javax.swing.GroupLayout.PREFERRED_SIZE, 14, javax.swing.GroupLayout.PREFERRED_SIZE)
                    .addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false)
                              .addComponent(jLabel3, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                              .addGap(3, 3, 3))
                         .addGroup(jPanel3Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE)
                              .addComponent(jTextField1, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel2, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField2, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField3, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel12, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                              .addGap(3, 3, 3))
                              .addComponent(jTextField7, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel11, javax.swing.GroupLayout.PREFERRED_SIZE, 49, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField8, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jTextField9, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
                              .addComponent(jLabel14)))
                    .addGap(35, 35, 35)
                    .addContainerGap(329, Short.MAX_VALUE))
          javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
          jPanel1.setLayout(jPanel1Layout);
          jPanel1Layout.setHorizontalGroup(
               jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
                    .addGap(0, 860, Short.MAX_VALUE)
                    .addComponent(jPanel3, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE))
          jPanel1Layout.setVerticalGroup(
               .addComponent(jPanel3, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
          jTabbedPane1.addTab("tab1", jPanel1);
          javax.swing.GroupLayout jPanel2Layout = new javax.swing.GroupLayout(jPanel2);
          jPanel2.setLayout(jPanel2Layout);
          jPanel2Layout.setHorizontalGroup(
               jPanel2Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addGap(0, 1045, Short.MAX_VALUE)
          jPanel2Layout.setVerticalGroup(
               .addGap(0, 528, Short.MAX_VALUE)
          jTabbedPane1.addTab("tab2", jPanel2);
          javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
          getContentPane().setLayout(layout);
          layout.setHorizontalGroup(
               layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
               .addComponent(jTabbedPane1)
          layout.setVerticalGroup(
          pack();
     }// </editor-fold>
     private void addMap() throws Exception {
          jPanel1.add(createUI());
     private void jTextField1ActionPerformed(java.awt.event.ActionEvent evt) {
          // TODO add your handling code here:
     private void jTextField2ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField3ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField4ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField5ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField6ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField7ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField8ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jTextField9ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
     private void jPanel1ComponentShown(java.awt.event.ComponentEvent evt) {
     public JComponent createUI() throws Exception {
          JPanel contentPane = new JPanel(new BorderLayout());
          MapOptions mapOptions = new MapOptions(MapOptions.MapType.TOPO, 41.9000, 12.5000, 12);
          map = new JMap(mapOptions);
          contentPane.add(map);
          return contentPane;
      * @param args the command line arguments
     public static void main(String args[]) {
          java.awt.EventQueue.invokeLater(new Runnable() {
               public void run() {
                    try {
                         new Main().setVisible(true);
                    } catch (Exception ex) {
                         Logger.getLogger(Main.class.getName()).log(Level.SEVERE, null, ex);
     // Variables declaration - do not modify
     private javax.swing.JButton jButton1;
     private javax.swing.JLabel jLabel1;
     private javax.swing.JLabel jLabel10;
     private javax.swing.JLabel jLabel11;
     private javax.swing.JLabel jLabel12;
     private javax.swing.JLabel jLabel13;
     private javax.swing.JLabel jLabel14;
     private javax.swing.JLabel jLabel2;
     private javax.swing.JLabel jLabel3;
     private javax.swing.JLabel jLabel4;
     private javax.swing.JLabel jLabel5;
     private javax.swing.JLabel jLabel6;
     private javax.swing.JLabel jLabel7;
     private javax.swing.JLabel jLabel8;
     private javax.swing.JLabel jLabel9;
     private javax.swing.JPanel jPanel1;
     private javax.swing.JPanel jPanel2;
     private javax.swing.JPanel jPanel3;
     private javax.swing.JPanel jPanel4;
     private javax.swing.JPanel jPanel5;
     private javax.swing.JSplitPane jSplitPane1;
     private javax.swing.JTabbedPane jTabbedPane1;
     private javax.swing.JTextField jTextField1;
     private javax.swing.JTextField jTextField2;
     private javax.swing.JTextField jTextField3;
     private javax.swing.JTextField jTextField4;
     private javax.swing.JTextField jTextField5;
     private javax.swing.JTextField jTextField6;
     private javax.swing.JTextField jTextField7;
     private javax.swing.JTextField jTextField8;
     private javax.swing.JTextField jTextField9;
     // End of variables declaration
     private JMap map;
</code>
EricBader
Honored Contributor
So, you are doing this:
Try:
- creating the BorderLayout explicitly.
- add the JMap to the center of the BorderLayout.
- Add the BorderLayout to the JPanel. for example: contentPane.setLayout (theBorderLayoutWithJMap)
