Printing [fit to one page]
4559
6
02-06-2014 09:42 AM
IbrahimHussein
Hey,  I followed this http://resources.arcgis.com/en/help/runtime-java/concepts/index.html#/Printing/01qv00000084000000/ to set up a print button on my application. The only problem I am having is making the map fit on one page. any idea how do achieve this?
IbrahimHussein
Whats the screen resolution you are working on?
Just for a quick test try DPI 150, then 200 and 300 and see what happens !!!
Hey sorry for the late reply, resolution is 1080P. Not sure if this is the right method of what Im trying to achieve.  See here, that's basically what happens to the map when I change the dpi. whereas im looking for the map to be filled to a single page. If you have the SDK for WPF, im basically looking to do something similar there on how it prints.
edit: ok got it, this is what I did. I saved the map as an image, and from there was able to print nicely. I used u/helengeb method to export an image,  seen here,for saving the image
Thanks for the help sachin.
SachinKanaujia
I am not very clear on what the exact problem is. Have you set up the Paper size and Orientation? How are you setting that?
IbrahimHussein
Hello, Yeah PaperSize (8.5 by 11) and Orientation is set up using the print dialog. To rephrase my problem, if you look at the image http://i.imgur.com/A3Bggv2.jpg; the map prints using 3 pages, is there anyway to have make it fit on one page? [ATTACH=CONFIG]0[/ATTACH]
             Paper paper = new Paper();
             // ...set up the paper options...
             PrinterJob printJob1 = PrinterJob.getPrinterJob();
             PageFormat pageFormat = new PageFormat();
               if (printJob1.printDialog()) {
                     try {printJob1.print();}
                     catch (PrinterException exc) {
                         System.out.println(exc);
             //set up page format [DEFAULT] options and pass the paper settings through
             pageFormat.setPaper(paper);
             pageFormat.setOrientation(Integer.valueOf(PageFormat.LANDSCAPE));
             // set page format for the map to print
             map.setPageFormat(pageFormat);
             printJob1.setPageable(map);
             try {
                // send job to printer!
                printJob1.print();
             } catch (PrinterException e) {
                // handle the exception
SachinKanaujia
You can use the DPI option while printing to adjust printing according to the paper size
     int DPI = 96; // change DPI accordingly
     MediaSize size = sizeMap.get(sizeList.getSelectedItem());
     double width = (size.getX(Size2DSyntax.INCH))*DPI;
     double height = (size.getY(Size2DSyntax.INCH))*DPI;
     paper.setSize(width, height);
     paper.setImageableArea(MARGIN, MARGIN, width - (2*MARGIN), height - (2*MARGIN));
I hope this helps
IbrahimHussein
I hope this helps
Thanks, still haven't got it, but definitely stirs me in the right direction.
SachinKanaujia
IbrahimHussein
