MapView center point
1063
08-13-2019 02:15 AM
S_MMaruf
How to get MapView's center point using method if there is any? or Hints how to get it from MapView in arcgis java sdk?
MarkBaird
The current area covered by your mapview is the ViewPoint.
You can read the Viewpoint into an Envelope geometry.  From that Envelope you can call getCenter() which is the centre point of your screen
Envelope extent = (Envelope) mapView.getCurrentViewpoint(Viewpoint.Type.BOUNDING_GEOMETRY).getTargetGeometry();
System.out.println("extent " + extent.toString());
System.out.println("centre " + extent.getCenter().toString());
Is this what you are after?
