Is Java ArcObject 10.2.x Supported on Solaris 10?
2328
06-19-2014 06:59 PM
HenryKo
Is Java ArcObjects 10.2.x supported on the Solaris 10 64-bit platform?
The following system requirements page does not explicitly say so:
http://resources.arcgis.com/en/help/system-requirements/10.2/index.html#/ArcObjects_SDK/01510000006n...
However, Solaris is used to be supported back in 10.0:
http://help.arcgis.com/en/systemrequirements/index.html#//01510000006n000000
Thanks in advance.
HenryKo
I have just read the following statement in ESRI's latest deprecation plan document (http://downloads2.esri.com/support/TechArticles/W28703_DEPRECATION_PLAN_FOR_ARCGIS_10_1_and_10_2__Up...
ArcGIS 10.1 will no longer support the Solaris versions of ArcReader and ArcGIS Engine.
I believe this statement can be translated to Java ArcObject 10.2 can no longer run on the Solaris platform?
Can someone confirm?
GriffinSchalow
That's correct, the last Solaris release of ArcObjects SDK Java was 10.0.
