Is it possible to create new Shapefiles?
996
11-08-2011 11:25 AM
DerekGray
Hello,
If a ShapeFile is in a map package, it is possible to read all the info contained therein, yes?
Is it possible to create and save new Shapefiles with the Runtime?
I'm looking for something equivalent to the following ESRI sample:
http://edn.esri.com/index.cfm?fa=codeExch.sampleDetail&pg=/arcobjects/9.1/Samples/Geodatabase/Creati...
Thank you,
Derek
RalfGottschalk
Hi Derek,
It is possible to read data from a shapefile.  However, it would not be contained in a Map Package as the packaging process converts data sources to File Geodatabase.  You can reference data in a Runtime enabled package, and the Runtime supports referenced shapefiles.
It is possible to create a new shapefile with Georprocessing.
