Invalid argument from GeometryEngine when drawing an ellipse
1734
12-09-2021 06:51 AM
Tone
I'm fairly new to ArcGIS, I do a bit of testing to see if we could use it for our application. I have a basic application displaying a map, and I want to draw an ellipse on it. I managed to draw circles, but for whatever reason I can't figure out, I have an arcGISRuntimeException : Invalid argument from the GeometryEngine when I run it with my ellipse.
Here is my code  (without my API key):
public class App extends Application {
    private MapView mapView;
    public static void main(String[] args) {
        Application.launch(args);
    @Override
    public void start(Stage stage) {
        stage.setTitle("Carto App");
        stage.setWidth(800);
        stage.setHeight(700);
        stage.show();
        StackPane stackPane = new StackPane();
        Scene scene = new Scene(stackPane);
        stage.setScene(scene);
        String yourApiKey =
        ArcGISRuntimeEnvironment.setApiKey(yourApiKey);
        mapView = new MapView();
        stackPane.getChildren().add(mapView);
        ArcGISMap map = new ArcGISMap(BasemapStyle.ARCGIS_IMAGERY);
        mapView.setMap(map);
        GraphicsOverlay graphicsOverlay = new GraphicsOverlay();
        mapView.getGraphicsOverlays().add(graphicsOverlay);
        EllipseFigure ellipse = new EllipseFigure(new Point(0, 0), 100, 100, 0, 0xFF00FF00);
        Graphic graphic = new Graphic(ellipse.getGeometry(), ellipse.getSymbol());
        graphicsOverlay.getGraphics().add(graphic);
     * Stops and releases all resources used in application.
    @Override
    public void stop() {
        if (mapView != null) {
            mapView.dispose();
public class EllipseFigure {
    private final double semiMajorAxis;
    private final double semiMinorAxis;
    private Point center;
    private double rotAngle;
    private int color;
    public EllipseFigure(Point center, double semiMajorAxis, double semiMinorAxis, double rotAngle, int color) {
        this.center = center;
        this.semiMajorAxis = semiMajorAxis;
        this.rotAngle = rotAngle;
        this.semiMinorAxis = semiMinorAxis;
        this.color = color;
    public Geometry getGeometry() {
        GeodesicEllipseParameters params =
                new GeodesicEllipseParameters(center, semiMajorAxis, semiMinorAxis);
        params.setAngularUnit(new AngularUnit(AngularUnitId.RADIANS));
        params.setAxisDirection(rotAngle);
        return GeometryEngine.ellipseGeodesic(params);
    public Symbol getSymbol() {
        return new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, color, 3);
I'd really appreciate if someone could help me figure out what's going on here.
MarkBaird
Hi @Tone
The ellipseGeodesic method is very fussy about its parameters.  You need to make sure you set them all and you also need to pass in a center point which has a known spatial reference.
I've created an example ellipse method which should help you:
  private Polygon makeEllipse() {
    // create parameters and set all the parameters
    GeodesicEllipseParameters parameters = new GeodesicEllipseParameters();
    parameters.setCenter(new Point(3,14, SpatialReferences.getWebMercator())); // Note the spatial reference
    parameters.setGeometryType(GeometryType.POLYGON);
    parameters.setSemiAxis1Length(100);
    parameters.setSemiAxis2Length(200);
    parameters.setAxisDirection(45);
    parameters.setMaxPointCount(100);
    parameters.setAngularUnit(new AngularUnit(AngularUnitId.DEGREES));
    parameters.setLinearUnit(new LinearUnit(LinearUnitId.METERS));
    parameters.setMaxSegmentLength(20);
    Polygon ellipsePoly = (Polygon) GeometryEngine.ellipseGeodesic(parameters);
    return ellipsePoly;
This is how I used the resulting geometry:
      SimpleLineSymbol lineSymbol = new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, 0xFF0063FF, 1);
      SimpleFillSymbol fillSymbol = new SimpleFillSymbol(SimpleFillSymbol.Style.SOLID, 0xFF00FF00, lineSymbol);
      Graphic graphic = new Graphic(makeEllipse(), fillSymbol);
Looks like this:
Let me know if this helps
Mark
MarkBaird
Hi @Tone
    return ellipsePoly;
Looks like this:
Mark
Tone
Ah, I knew I had a problem with the parameters but couldn't figure out what it was.
Thank you @MarkBaird !
