How to publish elevation service for JScene(Scene) in ArcGIS Rumtime for Java
5351
06-06-2015 02:02 AM
PavanRai
I am using ArcGIS Runtime 10.2.5 for Java. I have to show elevation data (dted) in 3D Scene. I published dted data as elevation service and added successfully on Scene. But the elevation data is not appeared on Scene(3D view is not visible).
Thanks
Pavan Kumar Rai
Arun_PrasadRamanujadoss
Could you explain the procedure that you used to add elevation service into the scene?
