How to handle authentication for inserting records into a Feature Table on AGOL from a java background service?
869
12-28-2022 09:03 AM
lochd
Hi. I programmed successfully using JavaFX to insert records into a Feature table on AGOL. For authentication, I did use a OAuthTemporary Token from my ESRI developer dashboard.
Here is the issue:
I have a scheduled background service running (Not JavaFX). The task will be executed once a day at 12AM. In the task, I want to program to insert records into the Feature table on AGOL. I am having issues with ESRI authentication.
If in the task, I use an OAuth Temporary Token -> It will work fine, but the token is shorted live. I need to open my ESRI developer dashboard to obtain an active OAuthTemporary Token everytime the token I am using in my code get expired -> The authentication process will need human involved.
If in the task, I use an OAuth Client ID & Client Secret  -> The authentication process will need human involved.
Is there a way to renew an OAuth Temporary Token if it get expired? OR any solution to solve my issues?
Thank you!
MarkBaird
oAuth is intended to be used as a client side authentication technique for UI based applications where you authenticate yourself by typing in a username and password.
I'm going to consult with a colleague who is more knowledgeable  about security for what you are trying to achieve.
Would you describe the process you are running as a server side / backend process?
