How to customize the InfoPopupOverlay?
2209
07-06-2016 08:00 PM
BatbayarBazarragchaa
I want to customize the InfoPopupOverlay to display feature attributes in different layout or design. Is it possible to customize its layout and design?
Or if it's not possible, how can I handle click event on each object (instance of feature class) of individual feature layer on JMap, so that I can display custom JDialog?
EricBader
Honored Contributor
Actually, the source for InfoPopupOverlay is in the Toolkit. The Toolkit source is available to you to refactor and recompile for your applications. You can find all the source files for the toolkit in <SDK_Install_Location>/sdk/jars/ArcGIS_Runtime_Java_Toolkit-sources.jar.
InfoPopupOverlay by default uses the PopupDialog to display information, which itself extends JDialog. You can think about modifying the source to bypass this and use your own JDialog if you want.
I hope this helps!
EricBader
Honored Contributor
I hope this helps!
