How to convert EPSG:3857 to EPSG:4326 in Sdk Java
7228
02-09-2019 01:06 AM
RafaelPaz
Hi, would like to know if there's a way to convert  EPSG:3857 to EPSG:4326 in esri Sdk?
Basically, I have a Point passing a y and x like this with Spatial Reference being web mercator (3857):
 Point point1 = new  Point(1.7040237624799997e7,-3099509.4953500014, SpatialReferences.getWebMercator());
Then I have another point with Spatial Reference WGS 84 (4326):
Point point2 = new Point(153.089361, -26.802295, SpatialReferences.getWgs84());
I need to convert the web mercator point (point1) to wgs 84 and get the lat/long of this point.
How can I achieve that? spent 3 days searching, but couldn't find anything on esri docs. Found
CoordinateFormatter class, but couldn't see how it could help.
Please, any help would be much much appreciated!
cheers.
nita14
Dear Rafael,
You should use GeometryEngine class for that. Check it here: GeometryEngine| arcgis-java and Project—ArcGIS Runtime SDK for Java | ArcGIS for Developers
Hope this helps.
Adam
