Errors ArcGIS Runtime SDK for Java 10.2.3 in OpenSUSE 11
2862
06-22-2014 01:40 PM
AntonioRodriguez1
I'm developing an application with ArcGIS Runtime SDK for Java 10.2.3. When I run this application in OpenSuse 11 the program fails with this error:
Java version : 1.7.0_60 (Oracle Corporation) i386
Rendering engine : OpenGL
GLX version 1.4
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: Required OpenGL extension is not available!
 at com.esri.map.JMap.nativeDrawMapDirectToBuffer(Native Method)
 at com.esri.map.JMap.paintComponent(Unknown Source)
 at javax.swing.JComponent.paint(JComponent.java:1054)
When I run this commands
glxinfo | grep OpenGL
it returns
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 2.1 Mesa 7.11
OpenGL extensions:
Has anyone managed to run an application developed with ArcGIS Runtime SDK for Java 10.2.3 in OpenSUSE 11?
Regards
EricBader
Honored Contributor
Hello Antonio,
The ArcGIS Runtime SDK for Java is not supported on OpenSUSE, nor any other SuSE distro, unfortunately.
The supported platforms can be found here: System requirements for 10.2.3—ArcGIS Runtime SDK for Java | ArcGIS for Developers
Ubuntu and RHEL are supported and we hope these platforms are viable options for you.
Thanks!
