Creating tpk file
25758
16
06-30-2015 05:25 AM
LAOJimmy
I would like to include a local tile cache (tpk-file) into a Java App because I want to have an offline mode.
I tried to download a small area from http://www.arcgis.com/home/item.html?id=e384f5aa4eb1433c92afff09500b073d  with ArcMap 10.3 but I get an error : 00005 : Layer type is not supported.
Anyone has solved this problem ?
Jimmy
Tags (4)
nita14
Hi Colin,
Open ArcMap (new blank document) and drag/drop tpk to the map window. ArcMap should automatically be zoomed to the extent of tpk. If it does not work, please answer the two following questions:
1) What is the size of downloaded tpk?
2) What is the area (coordinates) of the data you downloaded?
Regards,
Adam
by Anonymous User
Not applicable
Thank you for the reply,
Nothing is displayed when the package is drag and dropped into ArcMap. I have tried using different extents to see if that was the problem and still nothing shows up. The area I am trying to capture is quite small; the size of a small city.
The size has been consistently coming out around 2 Mb, which I think is quite strange to begin with.
Here is the extent I am trying to capture:
Note: I recently tried with a slightly larger extent and download a much bigger file (808 Mb) but still nothing displays when loaded into ArcMap.
Thanks again for your help!
nita14
HI Colin,
I recreated your tpk request. The REST API request page looks like:
The resulting tpk is 34.6MB large. I added the file to ArcMap, and I could display it at all scales:
Please, check your request parameters first. There must be something wrong there.
Regards,
Adam
by Anonymous User
Not applicable
Thanks Adam, I got it to work finally.
For the record, I was using Imagery and not world street map. I cannot figure out why it was not working before...but it works now!
Thanks again,
Colin
CHAITANYASHREE
how to get  tpk file of desired latlons ?
AlexanderNohe1
Honored Contributor
This might be better in a new question by itself as this question is marked as resolved.
CHAITANYASHREE
I have posted it as new question plz answer it
