Can't create a feature service
6715
17
10-22-2014 06:58 AM
ZahidCheema
I m trying to add new feature service at https://developers.arcgis.com/en/hosted-data/ but it says that “ title is already taken”. I have tried many different names but problem is not resolving. I need it badly for my project, Please help me as soon as possible.
EricBader
Honored Contributor
Something seems wrong with your account. I wonder if you can create a second one and try that. May I ask, are you using an English OS? A different OS? Is your browser IE, Fire Fox? Chrome? Safari?
EricBader
Honored Contributor
By the way, this issue may be more appropriate on a different space, like this one:
ArcGIS Online Developers
They may be able to assist you better.
This space is specifically for Java API collaboration.
ZahidCheema
Ok I'll try with a new account. My OS is windows 8.1 64bit English.
ZahidCheema
Anybody having solution about my problem, Please post.
PatrickArlt1
I've tried to reproduce this quite throughly this morning but I can't get it to happen when it shouldn't.
Can you give me a little more information about your environment?
1. Have you tried this with different browsers? If so which ones?
2. Can you try signing up again on ArcGIS for Developers. Does this work under this new test account?
(https://www.arcgis.com/home/createaccount.html ‌) then you should sign up on the developers site.
3. If you log into Arcgis Online and go to "My Content" do you see anything listed?
ZahidCheema
I did’t work. There is nothing in My Content. Now I really hate ArcGIS and going to switch to Google Maps. Good By.
VijayGandhi
Zahid,
The account for arcgis.com is different from account for developer.arcgis.com account, and the hosted data service you are trying to use works with a developer.arcgis.com account.
I suggest you create a developers account from Sign In | ArcGIS for Developers  and use that account when creating hosted data.
ZahidCheema
I am already trying it on my ArcGIS developer account but still not working. Its use less for me to waste my time on it.
