ArcGIS Runtime for Java in VirtualBox VM
2560
05-30-2012 08:04 AM
AdamHamner
Has anyone had any luck running ArcGIS Runtime for Java in a linux virtual machine?  I know it's not officially supported but I'm curious to know if anyone has been more successful than I have. Perhaps with a different virtualization software??  I have hitherto been using VirtualBox with 3d acceleration enabled and guest additions installed.
Adam
EricBader
Honored Contributor
Hi Adam.
I'm afraid you won't have much luck, if you are working with a Map in a visual application.
If you are trying a console-type non-visual app you may have some success there.
Doubtful that another virtualization software would work at this stage.
You are correct, though. Not officially supported at this point.
