ArcGIS Runtime for Java and Local Server access
4967
09-09-2014 12:53 AM
nita14
Hi All,
  I have heard that Local Server was made to share packages as services to local client only. Howerver, is there an option to access the services from another computer? How I can control the naming convention of local server address assignment i.e. http://127.0.0.1:port.
Many thanks for any suggestions,
Adam
EricBader
Honored Contributor
Hi Adam,
No, there is not a way for LocalServer running on a client machine to be accessed by another machine. This is by design.
The LocalServer is designed to provide local capabilities to that single machine only. A Runtime app is only intended for a single user to use on that one machine.
Does this make sense?
Thanks!
nita14
Hi Eric,
  Thank you for the answer. The 'Big Picture' of ArcGIS Runtime is clear for me. I am thinking about building high availability, mission-critical solution that does not depend on any server (ArcGIS Server Instances). Can ArcGIS Runtime local server instances communicate on multiple machines ?
Regards,
Adam
EricBader
Honored Contributor
No. Each instance of Local Server can only be accessed using localhost, so there isn't a way for one machine to communicate with another.
