ArcGIS Java Web Services 10.1
4166
04-25-2013 10:49 PM
KiranSomarapu
How do we set the proxy settings (of Proxy Server) in the java code when using the ArcGIS Java Webservices runtime jars to make a SOAP request to http://services.arcgisonline.com/ArcGIS/services/World_Imagery/MapServer? on a JEE server.
The below java code that sets the proxy system properties works with generated IBM JAX-RPC webservice but doesn't seem to work with ArcGIS (10.1) Java Webservices runtime jars:
System.setProperty("http.noProxyHosts", "*.xxx.com");
System.setProperty("http.auth.preference","Basic");
System.setProperty("http.proxyHost", "nameOfProxyHostServer");
System.setProperty("http.proxyPort", "8080");
System.setProperty("http.proxyUser", "kulja");
System.setProperty("http.proxyPassword", "simsim");
Authenticator.setDefault(new xxxAuthenticator());
Getting the below error when using ArcGIS (10.1) Java Webservices runtime jars:
activation.jar
arcgis_agsws_stubs.jar
arcgis_ws_runtime.jar
commons-codec-1.3.jar
commons-httpclient-3.0.1.jar
commons-logging-1.0.4.jar
jaxb-api.jar
jaxb-impl.jar
jsr173_1.0_api.jar
2013-04-25 22:32:14,345 ERROR [main] getMap - Exception while attempting to export map image
com.esri.arcgisws.runtime.exception.ArcGISWebServiceException: HTTP status code {407 - Proxy Authentication Required ( The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied. )} received from server
at com.esri.arcgisws.runtime.WebServiceProxyImpl.dispatchRequest(Unknown Source)
at com.esri.arcgisws.MapServerBindingStub.getDefaultMapName(MapServerBindingStub.java:268)
EricBader
Honored Contributor
Hello Kiran:
Try this one: http://forums.arcgis.com/forums/10-ArcGIS-Server-(10.0-and-prior)-Java.
This will be a more promising forum for your post, we hope!
Thanks!
MarkBaird
Hi
I might need to move your post so you can get a better answer as this forum is for native runtime apps.
Looking at your error messages I think you might be using Web ADF for java but correct me if I've got that wrong.
Let me know and we will get you some help.
Mark
KiranSomarapu
Hello Mark,
I am using ArcGIS Java Webservices jars that ESRI provides to make SOAP calls to the ArcGIS services on the Server from Java code running on a Jave Enterprise Edition Server.
I couldn't find a specific forum for ArcGIS Java Webservices (using ArcGIS Server 10.1), but do move it if there is a more appropriate forum so that I can get help on this.
Kiran
EricBader
Honored Contributor
Hello Kiran:
Thanks!
