Website navigation using a map
1257
01-29-2019 04:31 PM
TaylorNorton
Is there a simple means for creating an interface on a website where you can click a polygon on a webmap and it brings you to a new web page? I am attempting to create an app that displays a webmap of several watersheds. I want it to work so that when you click a watershed polygon, it brings you to a webpage that discribes that watershed.
Taylor
JacobBoyle412
Sure!
You can use URL strings in a field or stitch together a URL from a value in your table.
Using Hyperlinks—Help | ArcGIS Desktop
You can also enable them from ArcGIS Online/ArcGIS Enterprise following the below steps if you want to "Assemble" the URL from an existing field:
Enable Pop-ups.
Configure Pop-ups.
Select A custom attribute display under Pop-up Contents:
Then you’ll use the Custom Attribute Display to configure the popups. You can add fields you’d like to display at the top, then add the links:
When you setup the url’s, you’ll just enter a line into the URL string using the View HTML Source button:
Use this syntax:
<a href="https://google.com/{Code_Field}.zip/the_rest_of_the_url.htm" target="_blank">2015 Imagery</a>
Where {Code_Field} is the field that contains the reference value for the code.  The goal here is to stitch the URL together using field values and a normalized URL structure.
Let me know if you have further questions.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
