Label rotation in AGOL
958
10-20-2020 02:37 PM
MichelleSorrell1
Good Day All!
Have a standard annotation feature class containing measurements that's been shared as a web layer to AGOL.
The annotation comes through as a polygon feature with the measurements stored inside a field - TextString, which can be labeled using Label Features in the web map.  Is there any way to rotate the labels in the web map based on the angle field inside the attribute table?  Thank you for your time!
Another user asked something similar last year in the following link:
https://community.esri.com/thread/228747-rotate-labels-in-agol-using-json
