How to Load ArcGisPro SDK resources into a WPF app?
1440
09-11-2020 01:04 AM
deleted-user-JTyWy9b20ETO
I have an ArcGisPro Add-in using the SDK. As per the style guide, the UI controls use  ESRI colours, brushes and ProWindow instead of System.Window.
The Add-in is a DLL which is loaded into ArcGIS Pro.
I also have a Test Harness which is plain WPF Application that also loads the DLL and performs tests on it. This avoids the slow startup for ArcGis on my machine ( Can this be avoided by reloading the add-in?). It can test the UI without interacting with ESRI components likes Maps, Projects etc.
If I use ESRI resources in the add in, then the WPF Test Application can't see them and I get a compile error.
Error XDG0008 The name "DesignOnlyResourceDictionary" does not exist in the namespace "clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions".
My questions is how can the WPF App load the ArcGIS.Desktop.Extensions?
