How can I select points on either side of a vertex point?
2476
11-15-2018 01:09 PM
Jennifer_Andrews
Is there a way for me to select points that share a line with a vertex?  I'm trying to identify poles that are connecting cable going over the road.  Seems simple enough but I have yet to find a resolution.  Any help would be greatly appreciated.
rachelg_esri
Hello Jennifer,
I can't think of any out-of-the box solution, but you may be able to do some sort of manual or Python-automated selection process. Does your cable line ever back-track? If not, you may be able to use some sort of logic like this:
1) Get the objectID (or some other unique identifier) of the line feature the point sits on.
2) Select all points that intersect that line.
3) From the point selection, use a tool such as Near to find the nearest point to your road intersection point.
It may take some work but that's the closest thing I can think of off the top of my head.
Best of luck!
Best regards,
Rachel
Esri Support Services
Rachel Guttmacher
ArcGIS Online Technology Lead
Jennifer_Andrews
Thank you for getting back to me. I spent two days trying to figure this out myself.
Jennifer Andrews
GIS Analyst
Craighead Electric Cooperative Corporation
870-336-4416
JoeBorgione
If you have the correct license, you might  be able to turn your vertices to points and then perform a topology between those new points and your pole points.
Feature Vertices To Points—Data Management toolbox | ArcGIS Desktop
Converting vertices to point features—Help | ArcGIS Desktop
That should just about do it....
Jennifer_Andrews
Thank you. I will give this a try.
Jennifer Andrews
GIS Analyst
870-336-4416
