Hi Cody (and Nick)
Thank you for the feedback.
I can confirm that I am now using ArcGIS pro 2.3.0-beta 1 and I can now get the video frame to more-or-less match that of the video frame :-). But not always, it depends on device used to capture log file.
I have the Cirruas app loaded on two devices; a tablet and a phone. If I (1) record a log file using the phone, then, where it used to get the display error reported above, this is now fixed in Pro 2.3 (awesome). However if I (2) record the log file with my tablet, then I always get the below error in Pro only if I insert an elevation surface to calculate the frame extent. If I remove any elevation surface in the tool, then the tool will multiplex the video although it will have no frame.
If I try and run the video multiplexer in ArcMap, and set the tool to Calculate Corner Coordinates using an average ground height, then it is able to do so using teh log file where Pro failed. I have also upgraded my version of ArcMap and FMV extension so no more strange video frame errors being created from what I can tell.
The csv log files recorded using my phone and tablet look identical to me and I cant figure out why the one works but not the other in Pro 2.3 (and earlier versions).
As I am based in South Africa, the Cirruas app development team are having some trouble getting the regional settings sorted as the app inserts a comma instead of a full-stop as a separator between the elevation decimal values (thereby splitting my elevation value into two columns). I then always have to merge the two columns and then convert the new field to a number before trying to run the Video Multiplexer GP tool. I have to do this on log files produced on both the phone and tablet. I am not sure whether this has any bearing on the problem.
Cody, I will email you the log files to take a look at if you dont mind.
